seat seeger
  • Thread starter Thread starter luca donai
luca donai
hello to all, I am new as both user but also as inventor designer 2010.
a simple question: it is possible to do as with solid work a seat for seeger on a tree recalling a simple command i.e. insert seat for seeger, tab, etc.?
Thank you
impossible. has been implemented for years. Maybe we still call it that way, but you probably have to look in the tab "progettation"
- - - updated - - - -But if I don't remember you do a lot of things... but don't seeger:-(
you're wrong, only the operation for the seeger doesn't do it, but if you use the accelerator design for the creation of trees there is the possibility to put the seats for the seeger that calls "stop rings"
if the part was created with the "shaft" function under design (which would be of the old design accelerator), as you said inside there is the function to put the seat for "stop ring", just choose the norm and is created automatically. If the tree was created as a part, then it is necessary to make the seat manually with extrusion or revolution (I agree that it is quite scandalous that there is no special function).
