luigi sante zulian
Good morning I wanted to ask if someone was aware of how to perform example a seeger seat. on inventor you can use the design module or perform a sketch on the radial plane and with cutting revolution run the venue. or an offset plan creating two sketches and using the cut on the extrusion. but there's another way of offsetting a sketch that I don't remember... in solidworks before deciding the extrusion side in a menu, always in the command, there is a window asking you from, sketch plan, vertex, offset. The last gives you the opportunity to move the extrusion to a distance you want. See Annex.
