marcoevolution
I would like to know if someone has any idea why the partially threaded hole of the greaser is represented so
the realization of the hole is preceded by the genesis of a normal plane to the surface on site on which I applied a circle that I then destroyed (addition of material): obtained a flat surface I first made a smooth pass hole phi 3 and then on the same surface I made a threaded hole m5
the section is also passing through the center of the hole (in drawing environment)
clearly if I have omitted something do not hesitate to ask!
