sectional view
  • Thread starter Thread starter PiE81
PiE81
Hello.
is it possible in pro/e wf5 to create in a drawing a view with a half sectioned?
I mean, on the same view.. half section and half no.
Hello.
I use wf4, I don't know if it's the same. ..however you could create a section using the offset command, which allows you to draw the section track.
Hello.
Yes, of course, it is possible to call half a view, but you do not have to create an offset section, just take a planar section on the floor and when you are at table in the tab section activate half and select the model half-way reference plan. igo image
cation
