sections
  • Thread starter Thread starter ias87
Thank you very much.. .
But I would like to do soo section on the 2d... not on the 3d....
and write them to use right-click and property...ok...but if I make a plan....in 3d...
and in the 2d I want the section along that floor once right clicked property on the 2d then what do I do? ? ?
once you create the sections in the 3d call it back in the 2d.
when you are in the property menu go to sections, check cross section 2d and on create nuopa apply your section made in 3d.
Okay... I wanted to do the section only on table 2d... but if you can't then explain how to do it in 3d?? but you're sure that directly on table 2d can't do it? ?
I don't see anything sorry. Can you explain it in words? ? ?
section in the 2d I recommend... .
wait 5 minutes... There was a mistake in the footage and I'm charging it.
The first part of the film is 3d, the second part is 2d.
