sections
  • Thread starter Thread starter westy
westy
Good morning, everyone.
I have another question.
I need to make section views with the command "section" under the tab "place views" of some profiles for tightening and as in different points of assembly there is the same type of section, I would like to show on the design a single section view but referred to different lines of cut with same number.
It happens instead that every time you generate a section line you also create a view.
How can you do that?
thanks for the answers.
You can't do anything different if you don't cheat by putting out the sections you don't need.
by double-clicking on each section you can change the reference letter, so that the section arrows always appear the same.
