see only the oilline i'm building in bold mm 1
  • Thread starter Thread starter Alex97
Alex97
as I must proceed to see the thickness of a polyline. If I click line thickness and click display thickness, I see on the screen both thick and polylinea that I am building both all the lines already made, instead I want to see only mm 1 polylinea that I am building.
Started command, _pline, you can set the thickness with the _w parameter.
at the end of the command, it shows the thickness to 0 of the whole polyline through the _properties window.
