see the levels (annotations)
  • Thread starter Thread starter kubbah
kubbah
I can't see the levels (annotations) in a certain section, despite being activated in properties seen
Could you give me some advice on how to activate them and show them?
are designed and in a different section you see
a while ago I happened not to display some levels (annotations) on a prospective view despite activated. . .
How come?
some suggestions would be very welcome
thanks in advance
check that 2d or 3d levels extensions intersect the section plan otherwise do not appear.
What do you mean by annotation levels?
the levels, I speak of those annotations (orrizontal lines that are seen in section or prospectus) which indicate a certain quota
I'm practically scanning the whole plant to make them appear in section , moving the section on the weeping, but never appear, only 1 level appears
possible that I deleted them?
But if I gate them, shouldn't their respective views disappear?
can you recreate a level annotation and associate it with the view?
then I think it's what I meant...you go in a prospective view where you see both the section line and the levels, if you select a level at the ends appear of the balls with text 3d or if you click on 2d are the extensions of the levels...if these for any reason do not intersect the line of section the levels in that view you do not see them...to clarify the concept you can type examples of visibility in the project views... .
I hope that you will help me because nothing else comes to mind:rolleyes:
This was exactly the problem:)
the levels (annotation subjects) must be intercepted from the section to be seen!
Thanks for the tip!
