seeger rings feature
  • Thread starter Thread starter riccardo.ch
riccardo.ch
Hello, everyone!
I have the inventor's 2012 version and I wanted to ask you if there is a function for the creation of internal and external seeger rings (a little like the one to create bearings, or, etc.)
thanks for availability
Hello, everyone!
on the homepage of the forum in "search in this forum" try to put "seeger", for example..... .
I did so before opening this discussion; The last topic dates back 4 years, so I don't think I can help, having the 2012 version of inventor.
This is what it is not 4 years ago, and since then no news..... I miss with 2013 I think!
two years ago, in any case I meant that I had not found any topic that referred to the 2012 version.
so as suggested in that topic the only solution is currently to make a ifeature?
sin! thanks for availability
I'm not a moderator but for fairness I tell you that instead of opening new treads (almost making it clear to users that they didn't before carry out a search for the possible discussion that you are looking for) to continue an old discussion on the subject, though 2/4 years ago. this makes me understand that your little commitment to research you have put it, and you are not the "classic" user who does not even undertake to conduct research of old discussions.
I give you this speech because there are so many users who behave like this and who voluntarily avoid helping only for a matter of principle.
Hi and I'm sorry, but I don't have it with you.
I also thought about it, but at the opening of each discussion I noticed that it is required to specify the version of the software, so having the latest release of inventor I preferred to open a new discussion.
right to know (I am new to the field), but for the realization of the seeger rings that reference quotas you used (or use)? I hoped for the existence of a preset function, because in the project that I am making, I need to know the precise inner diameter of the ring in the conditions of assembly (the seeger in question I must install it within a hole), while the producers (at least those I found) specify only the quotas in the condition before the assembly.
the good dear and old friend "baldassini" always helps..... if you don't have this manual (if you are a mechanical designer/designer you must have it on the internet you look for the norm uni7435 and 7437 where all sizes of the seeger quarries are indicated according to the tree/foro diameters
I studied industrial engineering at thirty (I graduated recently), but the design understood as a design phase was very little considered; Let's say I have to arrange now and many things I'm obviously learning now.
I know how to deal with it, but designing is something else!
Thank you very much for your help!
