segmented radius
  • Thread starter Thread starter nkt
nkt
I'm making a cnc piece using visi.
are at the forefront of this software.
the problem is that when I go to do a contour milling, the straight surfaces are fine, while the rays are stranded (the radius turns out all to segments), as when in a cad program puts the coarse resolution.
How can I do to solve this problem?
hi nkt, also in the cam part there are "resolutions" to be calibrated.
If, pe., you are on a 2d path, you have tolerances within the "property" tab of the processing, at the top, before or second icon from the left. tolerance values should be reduced, arc segmentation should be dropped, etc.
in 3d you have t. already when you select the "pezzo" for the cam: toll. of something and toll. angle (to be reduced only if you finish, without ect overmetals, because they weigh on the calculation time). note that you can differentiate them face by face, to the need but with criterion.. .
and then, always inside the "properties" of the lav., at the top left, there are always additional tolerances to be able to manage, analogously to the 2d.
Obviously it makes sense to tighten tolerances or raise quality factors only to a certain point, if then the machine interpolates, to its insignificant judgment, in a more coarse way, for mechan/electronic limits or configuration of the cnc.
Good work, reborn.
