selection loss with pan
  • Thread starter Thread starter ilbona
ilbona
Hello.
use autocad lt 2015. I happen to select for example a group of lines and when I move with pan, I lose the selection. I tried to cuff in the selection section of options but I can't fix it. Does anyone enlighten me? Thank you.
I also noticed that the selection always works properly if and only if the items you are selecting are visible on the screen.
I think it's something you want to prevent the selection of objects outside the visual window.
the selection does not lose it if you avoid selecting objects when coming out of the screen (unfortunately the vice of "zoommare" and "pannare" leads you to do so even when you do not need it. I call this "disease." "zoommite"
I've got this problem on my PC. My colleague's not here. then it is about setting a variable or setting an option. I think. No zooming... .
