selection maximum shift structure
  • Thread starter Thread starter siax86
siax86
Hello everyone! I am a student with ansys :confused: I have a problem I am carrying out an analysis of an apdl beam, at the end of the analysis I would like to get a file of results that carry mass, maximum shift of the structure and maximum equivalent voltage, to vary the parameters imposed by me, regarding mass and tension there are no problems using the *get, while for the move I can not find the maximum command that allows me to select the vector.
I tried to use "*get,displmax,node,nodedispl,u,sum" but so I must first select a node but varying the parameters the node that undergoes the maximum shift varies.
Is there a way to select the maximum shift directly?
Thank you in advance! !
