selection
  • Thread starter Thread starter Shaba
Shaba
Me again..
in a view I would like to erase the axes that are also generated hidden holes
I don't find the system, I have to select one by one...
Omg!!
Is there a system?
Thanks :cool:
Meanwhile to delete them in groups activates the filter of selection centering notches
then to not have them at the insertion of the view just enter this in removal mode hidden lines
Have you selected the right filter? that represents a circle and axes, alongside the tilted line with the central point
Yes, yes.
see the image
the thing is very frustrating....
I resume this discussion to note that in the last image you show the selection rectangle so you have not yet completed the command, otherwise it would not be present. the selection is not carried out during the selection, but when you complete it by releasing the left button.
Obviously if you can select one by one you can also select them in group.
The only way that doesn't make me select them is when they are created with connection lines, but that's not the case.
a test that you can do to test the selection filter is that after activating the filter you have to press ctrl+a which is equivalent to selecting everything
