semicircular façade grille
  • Thread starter Thread starter luca67
luca67
I ask for help...
through the option "continuous facade grille" I designed a glass window with entrance door ( rectangular shape) ....
now I have to insert also a semicircular "surface" with relative pillars.......
Is it possible to create it using the "grille facade" command or should I move differently?
I have not understood well: the semicircular overlay you have to insert it in a window (continuous facade) ?
Or did you use a continuous façade to make a door in a window?
sends a drawing...
I send design hoping to be clearer...
cnq I have to insert the coat over the rectangular glass.
p.s. sorry but I am at the beginning of the adventure revit....
after making the necessary hole, insert a continuous surface-based façade (surface = hole)
