semisection view does not work with frame generator
  • Thread starter Thread starter rf.infissi@libero.it
I have a problem, and I hope someone can help me, if I carry out a semisectional view of a set or part belonging to elements of frame generator does not carry out the section but only eliminates the parts that are contained in the whole part not to display.
I can't explain why this is happening.
because they are standard parts from the counting center, so also behaves with bolt screws, etc... all that comes from the content center.
I don't know if it's on the table or in the environment together, I'll list the two solutions.
table:
method 1: Select from the browser or with the filter selection priority part of the portion you want to dissect, right button, participate in section and selections "section"
method 2: This way you will always section everything, even screws and bolts. tools -> application options -> drawing board, individuals the item standard parts of the section and the curtain menu selects "always".
together:
here choose whether to dissect always or never, you can't choose what to dissect and what not (it's not entirely true, but it would become an option of the part file *) tools -> application options -> tab together, put the flag to the voice dissect all parts.
*: if for a .ipt part you create go into tools -> document settings -> tab modeling, the flag on the item parcecipates to sections together and drawing decides the behavior in section of that specific file, so each file can have its own setting. If you notice, the components generated by the content center have that flag disabled, but you cannot change it and save them unless they are customized.
Unfortunately, so doing, now every time I repeat the installation procedure, when the program setup screen comes out with the applications to install, it tells me that inventor 2014 is already installed as well as the vault. only libraries have (justly) the check mark because they still have to be installed.
http://www.test-king.com/cert-cwna.htmhttp://www.test-king.com/cert-rhcsa.htmhttp://www.cnsu.edu/http://www.keiseruniversity.edu/
Can't I see what these posts mean?????? (It's just a xcasus virus)
