separate 2-line base region, then 2 rules
  • Thread starter Thread starter BerAnd
BerAnd
Hello, everyone.
I would like to know if any of you are already encapsulated in the following problem and if you managed to solve it:
I have to make a separate two-line base region (one for the component designed by the designer and one for the "mechanical commercials") that however must bring as first column the rpt_index parameter.
This parameter allows to "count" the table lines but, since I have two regions in the same table, the program starts again from 1 for each group.
someone had the same experience and maybe managed to have a continuous numbering.
Thank you all. :finger:
Hello, everyone.
I did something like that for my client.
he wanted all commercials to leave from 100-101-ecc.
I don't know if you might be okay with that.
Hello, Ozzy.
It is therefore not possible to have a continuous numbering but only to give a high number to the commercials from which to leave so that the parties never overlap the number of commercials.
But how did you get him out of 100? Are you having an affair?
but wait maybe I miss something, or maybe I don't understand...
That is, I have put as an example 100 because somewhere it will have to leave to not have the unique number, otherwise it would not make sense, no?
I did it almost five years ago and I think that in addition to the report I also put some special filters.
I'm looking for secrets tonight. :-)
Anyway, if you tell me the end, maybe I can help you better.
the end is to have a continuous numbering between the two lines of the repetition region.
In summary if I have 15 mounted parts of which 10 commercial I would like that in the rpt_index column there were numbers from 1 to 15 instead of one from 1 to 5 and the other from 1 to 10.
I hope I've been clear enough.
Clearly!
Then I think my method isn't good for you, maybe you have to use the imaginations.
I can tell you...:rolleyes:
I have a similar problem, too, but I couldn't take my feet.
If it were possible to find a solution would be great!
