bullet
Good morning. . .
I need your help... on how to proceed on a separate cutting material of solidworks.. .
I have this multibody part (example) so composed:
a first component is a 50x10 plate with 100 mm length...
the second component is a 25x5 plate with a length of 75 mm...
the third component is a 15-inch (extrusion) length of 60 mm upward and one (extrusion) length of 5 mm down...
when I go to complete the propitiaties of the three components for the first two dishes there is no problem... That is, I put in the description, dish. select the first dimension of the sketch that is in the first component is 50, digit "x", select the second dimension of the sketch that is 10, type "x", and finally select the value of the extrusion... in my cutting table will appear the description "piatto 50x10x100 and so far everything ok.
the problem arises in the third component, when I go to select the value of the extrusion.
I have the possibility to select the value of the first i.e. 60 mm, or the value of the second that is 5 mm... what I would like to know from you and if there is the possibility to insert the total of the two extrusions without inserting it directly (65) as if one tomorrow I go to change one of the two extrusions the table can be updated automatically. . I hope I've been quite clear. . .
Thank you from now on for your precious answers...:finger::finger::finger:
ps: I also tried to do research in other similar discussions but I found nothing to do with my case...
