enriazzo99
Hello, everyone.
I would need to ask for advice on how to arrange the cut distinction in a particular multibody.
Starting from the practical example I attach, I would like to make a table set aside for the particular 3 because it is a piece of milling and then give it its code. So I proceed with rescued bodies, I save the piece and make his table. How do I make a separate cutting table with a column that goes to recall the particular code 3?
Meanwhile I take advantage of another question: is there a possibility to have the name of the tubular in Italian (the same speech for the plates)? and why instead of the material "aisi 304" comes out "steel"?
