separate extrapolar base from together
  • Thread starter Thread starter FabrizioL
FabrizioL
Good morning, everyone.
I use nx5 and when I need to extrapolate a separate base from a collection I carry in an electronic sheet the axiemi navigator shaft but in this way I do not have the column quantity, someone knows a method to add the column quantity to the axiemi navigator tree, or knows another method to extrapolate a separate base (on spreadsheet. not text!)
Hi. a tip... presented on the forum...
Anyway, create the part-list, carry it in txt format and import it into excel.
when it amounts in excel set the width of the columns.
Good job!
If I create it with a part list I can't see the distinct levels, so I prefer to extract it from the navigator. I would practically need to extrapolate from quite complex assemblies the distinct level, the denomination (inserted as an attribute), the code (inserted as an attribute) and the quantities; all this information is found in the axiemi navigator but not the quantities.
Okay, I get it, you want the structure. .
dx button selects together - compress.
After that always with the dx button on the attributes columns, add the quantity column.
and carry, or in the browser or in an electronic sheet.
It works!
Good job!
First of all thanks to the attention you give me! but we are not there because I do not find to insert the column quantity.
In practice, they select the assieme father, I release it all and pack it all (with dx button on the column label of the browser together) in this way I see the complete structure where the multiple codes in the various axiemes are compressed and in the column "descriptive part name" appears in addition to the name but in a single string, at this point I expected to be able to insert a column quantity (with dx button on column columns instead
In this way it is true that I know the quantities because they are reported in the column "descriptive part name" but in the spreadsheet I have to copy them by hand.
Right. I just checked on the old version and on nx5 the quantity column does not exist.
It was inserted from nx6 forward.
the only thing that comes to my mind is the amount attached to the compacted components.
Good job
the important and knowing! is all afternoon I try to find a way to insert the column quantity. Now that I know that in nx5 there is not I put my heart in peace. I'll keep doing it by hand.
