spantik
Hello, everyone.
Maybe I didn't do a thorough search in the forum (maybe I try with the wrong key).
I have the following problem: I designed a compression spring, but how do I manage it separately?
I'll explain better, the spring is a single component that I can't have a code, because then in separate instead of the latter, I find myself "compression spring"; instead of being a particular, it turns out a set (for the very management of design acellerator).
then returning to the question: how do I manage it? Is there a saving in my name? (also because each part of this type, it generates me in the folder a subfolder with the same name as the code in which it is inserted)
Sorry, I hope I've been clear enough, in case I try to be clearer.
thanks as always to all for any suggestions
