separate material together based on a property
  • Thread starter Thread starter 320i S
320i S
hello to all, I need to create tables dedicated to spare parts, the explosions are already there, but instead of bubble everything or partially according to the explosion, I would like to bubble according to a property (change in this case).
the top would be that by inserting the separate custom material table, only the elements that have the "change" property are displayed, while all other elements are automatically excluded.
Is it feasible?
should be possible to do so with the equation in the distinct.
later I see if I can do some tests, but in short it would be a question of writing in the spare column an equation that commands: if you find the replacement value then show the line otherwise hide it. then you would want to save the table as a template and use it when necessary
I'm saying it's a reminder of something that's been done a long time ago and I have to take the speech back.
I was wrong about the equations. It is not possible through these, at least for me, to hide a line.
the solutions I found are:
-create a special configuration and through advanced selection filter all parts that do not have the spare property, then right>propriety> excl. should also work on subassistances
-in the cut-off section select the spare column then right-click and group all parts with that property; at this point select all the others and hide them
ok, it works, with the fact that then you can copy the explosions from one configuration and the other, you can make consistent views with the mounting ones.
Thank you again!
hello to all; I join this discussion. . .
I have boards made in solidedge, already quoted and stamped; I would like to insert in the bubble connected to the individual detail, the code of each element (as in solidworks, where you go to choose whether to insert the progressive number connected to the material table or the code part etc.);
I found the list of properties (with codes) but I can't find the one linking the filename of the single part, but only that of the code together.
How do you do that? Can you help me?
Thank you very much
Excuse me! I used the search function and didn't realize I was under sw...
delete the posts as well!
