separate tubes with tilted cut.
  • Thread starter Thread starter gil
gil
for information purposes are to ask: designed a sketch as from drawing below (treated lines)
picture.php
then, using the sketch insert square-section tubular. Finally making a distinct material, it appears that the measurements of the inclined tubes are related to the measurement of the sketch is not the length of the pipe to be cut (see drawing).
is the problem solved? Thank you.
Thanks I try to follow the directions of the other post.
However it is not clear to me where I have to enter the b_l value in iporprietis to replace it with g_l.
I'll see if I'm looking, thank you.
