War82
Good morning, I wanted to ask after several searches in the forum if someone had had had my need.
I use creo 3 with windchill 10.2 and my goal is to create the distinct parts directly in windchill.
I set the owner function for the wtparts and until the processed management, assembling and sub-assisting all ok.
My problem is that I can't view the crude that I create " amounts" in the work with the merge function.
I ask therefore if the merge management manages to manage it windchill (which obviously feels like I create bond but not as codes and therefore distinct, unless you manually impose the wtpart code bond)
thanks, greetings
Daniele
thanks, greetings
Daniele
