series - countryside
  • Thread starter Thread starter Marco74
Marco74
I should be able to make a particular parametric where at the varying length z and øy may vary x (driving distance), where x must be between 95-105 mm, useless to say that the first step x is a hole (features) which will be used for sampling.
at what distance x (formula) I have to make the first hole of øy because x is between 95 and 105 mm. then do the sampling for all z of the same distance x?
I hope I've been clearer.
Bye.
in the example I sent you by mistake I exchanged x with y (I put x as hole diameter and y as intermediate space). then I didn't understand the 95-105 speech....
that would have been the least, now I can't open your file because at home I only have 2d free, then Monday at work I look at us.
maybe needed help composing the right function. :wink:
I attach an example, in which imposing values of z, x, n, is automatically calculated y.
exactly what I was looking for.... aside from the speech to understand how to set the variable that x is between 95 and 105.
Bye.
