series of a long trajectory object in the environment together
  • Thread starter Thread starter davide75
davide75
Hello, guys, I wanted to know if you can do it in an environment together with serializing a component along the trajectory.
I couldn't do it for now.
advice? ?
hi davide, you can, although in a different way than a part.
So what you have to create is a part that contains your path (scratch 2d or 3d), always within the serialization part along the path of references (planes, points, surfaces, etc.).
insert that part into the axieme, bind it in place, then serialize in the environment together using the feature pattern select option by selecting the part series support, in practice serialization using the part series and its path.
I tried, I created the part, I sketched on a trajectory (like a spline ), but I can't serialize references. Maybe I'm wrong. don't you have an example of the part that contains the trajectory so I look good at the tree of the model? ?
The rest is simple because to make belt teeth I have no problem but it's always about serializing a workmanship within the part, so I don't think there's any problems for the axieme once you know how to make the part that contains the trajectory.
View attachment Nastro.rar
I don't understand what you mean by references and why you want to make a set of the toothed belt and not a part.
If you care, I can attach a tape I did years ago.
I thank you, but maybe I was misunderstood.to do a series of work along a trajectory I can until I stay inside the part (see belt ).if I have to do the same thing together I can not.
I try to tell you with different words the method of Pompeo79
in the environment together the series command proposes three tabs: the first is select series of processing. when you choose the part you want to serialize "follows" the serialized processing that you go to select on the "guide" part.
For example: you have a conveyor belt with a set of holes for the banks, together add the bracket and the constraints to the first hole. with the command "series > series of processing" then select one of the serialized holes and the bracket will serialize itself. It's very convenient, even though I suppose you use "mass" slowing things down. I always use it and never gave stability problems.
