series of non-regular components
  • Thread starter Thread starter d-prom
d-prom
Good morning, guys. problem: if I do a hole in one part and then the multiply with the command "series" then, in the together, I will pitch a screw (or anything else) in the hole I can create a series of components linked to the series of holes, which automatically updates by changing the series of holes. and everything's fine. the trouble is if I have a plate with a set of holes placed without a precise rule, which then I am forced to place with a single sketch and quota one by one: in this case I am dismembered myself or just cannot make a series of screws tied to the series of holes?
precise that in solid works, on the contrary, the command "series guided by function" also takes the series of holes arranged to the male dog sexual organ with a single sketch, while in proe there is the so-called "table" series that does more or less the same work.
I wonder why I recently had a plate with about thirty holes, and the screws that went into those holes I had to place them and bind them all one by one, with a great loss of time (in addition to dismay).
Thank you in advance.
instead of using the "for hole" function uses the "concentric" function (or in some cases "on point", but you have to create in the part all user points for all holes, useful for the sunshades....). what you can do with one conn command. bolted more holes scattered and sees them as the only series.
I'm sorry, you could explain a little better because I didn't really understand how you do it.
Immagine.webpin "position" first selections "concentirco", then select one of the holes, then select the termination plan, then return to select "reference/circular/i" and select all other holes. if you do not select first the termination plan dvi every time you return to take the "reference/circular" fungus every time you select a hole.
the same applies to the "on-point" function only that each hole must have a reference point created in the part.. .
