blue.cat
Hello everyone, I press that following this post:
http://www.cad3d.it/forum1/showthread.php?t=6733&highlight=scanalatureI couldn't solve the problem, so I ask you to apologize if I create a post of study.
I have to recreate a wall with outer cladding of wooden strips 5x5 cm and spaced between them 5 cm, to do this I wanted to use the groove command (after having added in the stratigraphy of the wall in question an external layer of 6 cm of wood).
as indicated in the previous post I consulted I created a new channel profile through a new family, I dissected the properties of the wall > change structure, but the underlying button "scanalature" is activated only if they select in "preview" the vertical section (if I try selecting the "floor plan", that is to say the horizontal section of the wall, the keys remain all disabled). doing this, when I select the profile I created, a horizontal, not vertical groove is created.
also to carry out a series of grooves (i.e. along the whole wall) do I have to give an "offset" in the selection properties of the groove?
thank you very much for the advice and apologize again the repetition.
