series on curve to model a conveyor belt
  • Thread starter Thread starter makeng
makeng
Hello, everyone.
I have sought solutions to a problem that I cannot solve: create shores on a conveyor belt that are always perpendicular to the curve. I tried to apply some solutions in the forums but without success. the banks are all oriented towards the same direction. I made a single (spline) closed curve, obtained a point on curve, defined a perpendicular axis, but it does not work. I am convinced that the solution is behind "the corner" as usual in proe, but I didn't even find the corner.... Can anyone help me?
Mar
try to see this example.
I used wf3 not knowing your version.
Thank you. Now I try. I use the wf5 030. if there is a better optimized command is definitely better. .
But there's still a little problem. I have inserted a lenght future calculation with the development and a linked layer file I can insert the number of banks. calculate the step of the banks and insert in the series the calculated step parameter. orbene I can't insert the number parameter of shores from the layer in the series so that the regeneraizone is fully automatic without manually inserting anything:confused:. Can you do that?
Thanks for the help.
I have noticed that, more generally, there are two orders of problems:
1) parameterize from layout the number of repetitions of any series:
2) insert within a layout file a parameter of a declared part connected to the same layout. For example I would like to have within the layout the development parameter detected and converted into a parameter from the tape model so as to manage ... maybe I ask too much? We hope not!
Mar
