set classical work area in autocad 2010
  • Thread starter Thread starter MAX.SS
MAX.SS
Hello I read that to have the bar with the classic commands in autocad 2010 you have to select it on "work areas" my problem is that I find only one area of work called "architectures"..how can I do to solve this? Thank you.
I also miss the command line. ..what indicates what you are doing to us
If clikki where indicated by the arrow, does not the classical work area also come out?
thanks for the answer
no there is... in fact I had tried how to put it but not finding the solution I opened a discussion... how can you do it?
in architecture as in civil 3d does not exist by default the classical work area. check if you have a profile <<autocad>> (in civil there is) otherwise it is up to you to build it alone</autocad>
there is no autocad profile.. .
to build it alone I don't know, but I can't remove the classic multifunction bar to switch to icons and get the good command line out. .
I wondered if you could put a .cuix file already arranged to overwrite to my..
for the command line ctrl + 9
to change the work area see if you can change menus, search in the pc if there are acad.cui or acad.cuix.
ok the command line is set. . .
for the file I found " acad.cuix " with this path:
c:\program files\autocad architecture 2010\userdatacache\support
menu command, and go to select the whosex you found. check that the path is placed in options/file
Yes but first you have to download the cuix of architecture, otherwise it makes him a big mess!
ok, well or bad I solved by uploading the acad file:
Now I just have to fix the bars I need. .
but is it normal that icons are so large?on rhinoceros are much smaller. .
Thank you all for your help! !
of course you have active this:
options -> display -> uses large buttons for toolbars
Thank you. !
other question. .
I was trying the various commands when I press it says to me:
command: _fillet command unknown "fillet". press f1 for the guide.
while the top says:
command: _chamfer command unknown "chamfer". press f1 for the guide.
what can depend on?
edit:
if I write fitting on the command line goes...while it does not go from the icon and the drop-down menu.. .
Thank you. !
other question. .
while the top says:
what can depend on?
edit:
solved by writing the command in Italian on the macro.. :smile:
