MORENO100
Good morning to all,
I can't find the name of the setting that sets the position of the mask to create auxiliary parts.
I better explain, for a solid type part you can set in the config.pro command "template_solidpart" to specify the path of the file "mmns_part_solid.prt" that will be used when you want to create a new solid part.
I would like to be able to set the path of the mask "mmns_part_bulk.prt" to use in the creation of a part of type auxiliary but I do not find the command to use in the config.pro.
thanks and good day.
p.s. use creo 2.0.
p.s. use creo 2.0.
