Set New Origin on Visi 17
  • Thread starter Thread starter mytyko74
mytyko74
Hello, everyone. I'm an alessandro and I've been writing for a very short time. work as a cnc milling machine using visicam.
we installed today version 17 (until yesterday I worked with the 14) and unfortunately I can not set at the cam a different origin than the absolute one.
In practice I can make a new one, the work is done on the latter but the post remains on the absolute origin.
Can anyone tell me the right procedure? ?
Thank you in advance and wish you a good weekend.
alessandro
hi try by setting the relative number of origin on the properties of the cam setup if you still do not get the result you wanted to select also active positioning select the reference origin on which you want to move your origin to update cam setup for safety and at this point work as if your relative origin was like the absolute.if you did well you should see that the cam setup becomes blue.
Good work bye.
Hi. .
thanks for the info. the problem was solved by changing the machine settings. Thank you for your concern.
Good work to you too.
