set sheets "no export"
robertobartola
can you set sheets or better than "right" (detail sheet) so that by exporting the drawing in pdf or dxf they are automatically excluded and therefore not generated the relative files?
I'd better explain if I hadn't been clear enough.
the configuration with which I work with a customer previews to have sheets (normal sheets) for the boards while of detail sheet (it seems to be translated as "right" in Italian) for the drawing formats, the symbili, etc.
hypothesize to have a drawing (aaaa.catdrawing) so composed:
- sheet.1 (the real table) - a real sheet
- formats (sizes with a0, a1...) - a detail sheet
- symbols (most used symbols) - a detail sheet
if I export the pdf of the catia document export the following files:
aaaaaa_sheet.pdf
aaaa_formati.pdf
aaaa_simboli.pdf
And I find myself every time I have to cancel the last two.
I would like to configure the startpart so that the two detail sheet do not generate pdf.
Is that possible?
roberto
yes when you carry pdf in the press menu there is a potion with which you define whether to export a single sheet or more sheets etc.
but the configuration menu 1/plus sheets only appears if I use the print command.
if I make "save as" and choose pdf there are no menu
ok but what if you use the print command instead "save as"? your goal and have a pdf of a sheet
Sorry, I wasn't clear.
I try to be clearer.
I'm generating start parts for a customer.
what I would like to understand is if you can configure a drawing (so a start drawing) to have sheet that are default not processed in output, both for prints, and for export pdf, dxf ...
so I would like to understand if there is a "parameter" for which certain sheets are "highened" in case of work output.
I thank you for your answers and I hope it is clear
roberto
