set to default cartiglio with nx 11
  • Thread starter Thread starter icmea
icmea
Hello everyone! use nx11 and I would like to set a custom default cartiglio. the original is that siemens, while what I would like to do should automatically set the name of my company.
with nx4 the procedure was quite simple, so it was enough to use this procedure:
c:\programmes\ugs\nx4\ugi\menus\custom_dirs.dat
open file with notepad
correct path: c:\programs\ugs\bck_cartiglio_nx4
incorrect path: c:/programs/ugs/bck_cartiglio_nx4
This with nx11 doesn't work, so I'd like to know if anyone knows how to do it.
Hello icmea,
seeing the names of the files you posted, the cartiglio doesn't work because in nx4 you used an external tool developed to och. to use the same tool with nx11 I think it should be reconfigured for the new version of nx on the new installation. to reconfigure it I think you will have to contact who resended the tool.
if you want to use the standar commands you will need to remake the templates.
in the drafting sheet you have these commands:
edges and areas - to set the edges of the sheet with all its features.
Define cartiglio - to set the table containing all notes
Before you do the command you define cartiglio you have to create your table with the command of tabular notes (table notes) and set it all graphically, with all your pre-compiled fields.
after finishing the table converts it to cartiglio blocking size and cells, leaving free and with untitle only those that will have to be compiled.
do these two steps rename the file with template names and move it to your template folder.
advice, if you want well-made paperwork with automatic attribute calls and template setting, try to hear your nx dealer, who sees the old carts can give you some more specific advice.
good day pizza3d
