thetmd
I tried to search inside the forum but without luck
then the question is this:
I remember that in autocad there is way, within a layout, to set the coordinate 0.0 a partide from the edge of the sheet instead of the margin of the print area... .
Where do I find this command?
I tried in the options: tab "plot and publish" - box "specify plat offset relative to" - and set the option "edge of paper"....but did not draw the desired result....
Do you have any advice?
pierpalo
pierpalo
