settaggio snap
ele.architetto
Good evening, everyone! are at the first weapons with revit and I was wondering if it is possible, and of course as you do, to change the size of the display of the snaps on the screen, to change the color of the line that identifies the inner/external thread of a wall when you insert the quota using the tab, and how you can activate the dotted guidelines that highlight the comlanarity for example between two odds.... I looked everywhere but did not find answer!
as you do, to change the size of displaying the snaps on the screen
I do not think it is possible; Why do you want to change the size?
how to change the color of the line that locates the inner/external thread of a wall when inserting the quota using the tab
changes the color of the preselection
how can you activate the dotted guidelines that highlight the complementarity for example between two quotas
I don't know what you mean.
...I wondered if it was possible to facilitate screen display and avoid blindness! on autocad are parameters that can be changed, so I wondered if even on revit there was this possibility. for the issue of the outlined lines I solved... thank you for the collaboration!
I don't think it's a matter of screen, I also use other programs that work nicely! I just started the revit course and installed the 30-day trial version from the autodesk site, with the recommended packages and I think I have occupied most of the PC memory...I see that however the speed of the program is not the same as the version I use at the course! I also noticed the different graphic settings between the version I use, revit 2016, and the one I use at the course, revit 2015, so I wondered if it was possible to set the parameters I told you...
