setting/modification separate table base
  • Thread starter Thread starter ndonio
ndonio
hello to all
I would need to know the procedure to change the table of the distinct base in cat drawing.
For example:
I need to insert a column that brings me the weight of the piece automatically.
In addition, the numerical progression increases from the top to the bottom: can it be reversed?
Can the insertion point be established for different formats?
Thank you all.
END
hello to all
For example:
Thank you all.
END
the table can be reversed by selecting it so that it opens all around a rectangle, by clicking it with the right mouse button and selecting "invert rows".
you can also insert the material and weight automatically, going to select on the product tools/distinct base, and indicating the parameters, which I should first create on every detail on: property/product/define other properties, and then assigning the formula to these two parameters goado to select the material and the value of the mass measure ch and you must acer calculated and savated uin previously.
only problem (at least as far as my version 17, for others I don't know) every time you update the design the table returns to be the initial one without the material parameters and weight.
for this I ask for advice, is there a way to save the format settings of the modified basics?
every time you close the cat and you reopen back to be the default ones.
to save the separate settings, start the macro recorder before running the "bill of materials" command. Finish the separate customizations close the panel normally and then close the macro recorder.
at this point at the reboot of the catia you start the stored macro and you will find the distinct settings.
ps.: I start the macro with a button of a custom toolbar.
max max
max max
Thank you! done now I just have to create the customised toolbar. . :biggrin:
hello to all
I found the solution and wanted to share it with all of you.
from the r19 there is the distinct advanced base command.
it is enough to customize the distinct accessing in administrator mode and the game is made.
Greetings to everyone.
Hi, everybody, I'm freaking out with a stupidity.
possible that in the separate table can not set the width of each single column? ?
The beauty is that this summer, I had found the way but now that I have to create the 2d I forgot how I had done! :finger:
I already have a macro with every single property to make it appear in the db, so I appear 6 columns but the widths do not define and you have to set them by hand (selecting the table, changing size)
you know better than me that every time you update the design the db explodes and you have to start all the tyra.
I tried to create a macro that reversed the lines and changed the widths but I couldn't.
the explanation given here by blackbird I can't put it into practice
opening the macro in which I change only the widths of the columns results without any command.aprendola I find only
language="vbscript"
sub catmain()
end
Who can give me a tip?
If I want weight for example, do I have to calculate it with the "inertial measure"?
if I add mass property to each part, this has value 0kg, is it correct?
how do I insert it in the formula?
Can I ask you some print screens from the various steps?
hello to all
I also use version 19, but the distinct advanced base command can only be used in catdrawing, while the modification of the distinct base is made in the catproduct, so I did not understand how this thing works.
other question, why do the automatic recurrence numbers come out different from the ball, and above all different from the number of recurrence that appears in the catproduct?
the voice "inverted lines" looks gray to me and I can't select it
How can I do that?
