Davyd80
Okay. . was just to specify what I used, but also 3ds uses mental ray, but the settings are a little different :dare already six versions that autocad "vanilla" uses mental ray. :tongue:
am4! :biggrin:I can only tell you he was in the lecco area.
undoubtedly; These are not the things that make an instructor a bad or bad instructor! to have us... good, not bad...also because it seemed like a good jaw
the thing is very trivial.. I don't know if you noticed that the view camera has 4 circular "grips" on the sides of the pane. enlarge view means increase the field angle, then change the focus!Can you tell me how?
autocad and autocad architecture (in the latest release) for what concerns rendering are almost identical!Davyd80 said:Unfortunately I think it is a little different (I use auotcad architecture 2011 that uses mental ray). .
Yes, it is. the engine is the same, but of course 3ds has a greater number of parameters for the set.Okay. . was just to specify what I used, but also 3ds uses mental ray, but the settings are a little different :d
the point of view changes it in at least 2 ways: either from the view in the plant or with steering wheel; the field angle manages it from the blue grips...but in this way you cut the image, you do not change or point of view or opening the room.. .
the image is exactly the same, only that you see what you want.. .
How irony!the point of view changes it in at least 2 ways: either from the view in the plant or with steering wheel; the field angle manages it from the blue grips...
...because I gave you the input, I don't want to waste time trying to convince you of what I say. Instead we do so, I joked, the attached image I created it with photoshop and I confirm that the goal of the revit chamber is fixed at 35mm (which then I would like to know how they calculated the focal, since in revit there is nowhere a "focus distance" parameter, not even read-only).
I understand that my interventions were really fried air. ....the topic of my discussion was not the focus of the revit chamber, me the rendering settings of autocad architecture 2011If no one can tell me It is useless to get lost in other speeches. . .
Toh, sometimes the parts reverse... :tongue:::36_1_12: boys....you are under control!
irony aside...it seems to me (as says gp) that the councils have been given to you but you continue uncleaned on your way. Have you tried what you were advised or not?How irony!
the councils ok... I tried them and they are fine, but they were also the most obvious things I had already set. . .irony aside...it seems to me (as says gp) that the councils have been given to you but you continue uncleaned on your way. Have you tried what you were advised or not?
