settling graphics card inventor 2012
  • Thread starter Thread starter dakota
dakota
Hello.
I use inventor 2012 and would like to ask if any of the forum can indicate me the optimal settings for the graphics card nvidia Framework 5000.
in the control panel of the board you can manage the settings but I don't know what parameter to change (overlayability, mutli screen acceleration, etc.) to get the best result of screen display.
at the moment, when I rotate a set with many parts, some disappear during the operation.
Thank you for your help,
Dakota
Hello.
Dakota
before going to touch the nvidia sects try to act as an inventor.
tools/options application/hardware
What values did you set?
test compatibility or quality, with the last unchecked item.
Thank you! ! !
I changed the values from performance to compatibility and the problem disappeared.
Thanks again for the excellent advice you gave me.
Dakota
Thank you! ! !
in 2011 I also solved so. in 2012 instead, when I turn around with a decent number of components the problem remains.
What seems absurd to me is that with graphics cards from hundreds of euri you have to set up in compactness instead of in performance.... is a countersenso.:mad:
...you're perfectly right.
Anyway, I think it's not a card problem but an inventor's problem.
Dakota
I am not particularly pleased with my painting 4000, the settings made me the (very competent) autodesk dealer, both at the level of inventor 2011 and card: updated graphics database files etc., proven compatiblity, quality, speed, etc. I not only have problems in non-banal assemblies (~20000 occurrences) but also in sketch and quotation environment: sometimes I do not see the last things drawn... in some forums I read that the finger is pointed against the fact that inventor uses directx rather than opengl like almost all other cads, and that then in the end there are tabs from vidogiocatore that go better than our sacred monsters. I'm sorry! !
I have like you a nvidia 4000, increasing ram (20 gb) I solved the small inaccuracies you found on the great assemblies. (which doesn't mean it can work with your thirst too).
now 20 gb (need to ram also for other software) maybe not, but with 20 thousand parts to manage 6 gb rams are a bit pulled, do some tests with 10/ 12 gb
I can also understand: I'm amazed that when I passed from my old geforce 7600 with old computer to this on hp workstation I didn't see almost any difference... With all the money that cost, I hoped better. As I said, I simply suppose it is not efficent with directx that inventor now uses :36_1_2: . however, returning to the 20000 occurrences; the ram is occupied to me at 65%, I see everything, I do a little zoom and it disappears half stuff, I just touch the mouse and the missing stuff comes back: Do you know more about refresh video card, or am I wrong? I ask, I'm no longer the cue of once.. .
I to overcome this problem I set in options-> display-> time transition views to 0 and frame rate to 0
Hello friends,
I tried to set the "compatibility" option even on a fx4600 nvidia board, with which I had the same problems as the 5000 picture, and it worked.
Dakota
