shading edges
  • Thread starter Thread starter Dave_TechnoMech
Dave_TechnoMech
good evening to all, I wanted to ask you if there was an option in creo parametric 2.0 that memorized the shadow of the edges of details, without having to activate it at every start. I also wanted to ask you what options I should add to facilitate the current design environment that is almost everything by default (you are unaware of my ignorance is the first time I use this software and it is not easy to understand). thanks in advance to all. Goodbye, good evening.
hi dave, to store the display type of models you have to set in confi.pro the option display shade for a simple shading, or display shadewithedges for a shaded display with prominent edges.
then for the configuration of the design environment makes faith another configuration file that has extension *.dtl. My advice is to start with a standard that follows for example the iso legislation, then as you draw you can add and/or change the options that you consider appropriate. after each modification it would be good to save the file.dtl reworked from another part and then to recall it in subsequent drawings or templates.
I hope I have grasped your doubt. soon and good work
thank you so much calacc you have grasped perfectly my doubt. Thanks to the next one. Good evening.
