susanna.pata
hello to all, I have a problem with shadows in my model 3d.
I created a surface from the ground level curves and then projected the curves on the surface and extruded the buildings. I would like to study shadows but I can't get the shadows projected on the ground.
I have already done everything I knew to do and found as a solution, that is:
- check 'shadows' from the display menu
- Activate rendering mode
- set solar incidence values from the 'toggle sun panel' by 'render tools'
How can I solve this?
thanks in advance
(I attach photos)
thanks in advance(I attach photos)
