fischer
Good morning to all,
I have a big doubt about the size of a tree for an electric motor with profile grooved at one end.
on the shaft a pair is produced (we assume 100nm on the 120mm stretch) between the two bearings; the same is transmitted outside through the above profile. the shaft is supported by two bearings (diameters ø30 and ø25 in the attached design).
I would like to calculate the radial load on the bearings, but for how I see it if the shaft is balanced (and if we lose the proper weight) the load is null.
Is this statement correct? (I hope it was clear in the explanation)
