shape a dagger!
  • Thread starter Thread starter User1
User1
help! who can help me, I can't shape this dagger! I started with modeling, but when I got to give a thickness to the tip of the dagger blade I got stuck! I would like to give the same thickness as the whole blade on the tip, but I can't because of the connections that are there!
thanks ezio! you don't have all the twists, I have published a .bmp while now I'm publishing the .catpart file typical of catia v5! thank you! My problem is to give a sharp thickness to the tip of the blade and I can't because there are fittings on the side faces of the solid! garzie but you find the problem with the 3d file!
but you don't have to worry about it, and then I work with catia and other software I appreciate so much autocad, I know it and use it often!
No problem! It was just to answer those who by trade do the "aguzzino"... who tried to laugh, maybe.
I had posted the result with autocad, and in fact it was not entirely automatic as I thought from the image of bmp. You made me rediscover the need to remain faithful to the forms! thanks tonyproge!:finger:
Don't think about who's trying to make sarcasm! part of the game! However, if you'd like to try one in 3d using autocad 2008 or 2010, I'll tell you this because from your avatar I see you're a autocad user! Hello and let me know!
Why didn't you like the 2007 model? Tony, what's so different in the realms you reported?
excuse ezio, I was not clear, also because autocad 2008 produces files for 2007. I said this because the software prior to 2008 always have some small limitation, and why I use autocad 2008-2010 and we could exchange quietly 2d drawing files and 3d models! when it comes to drawing and modeling I try to adapt to everything, important criterion for my professional figure! Let me know!
