share a dynamic block
  • Thread starter Thread starter Luigi1
Luigi1
autocad use 2010
I was following yesterday a videolet downloaded by prismacad on dynamic blocks and I can't insert a dynamic share in a block.
in the video is used autocad 2015, it seems to me. in the video does nothing but quote the block inside the editor, but does it work to me? or looked at the procedure several times and fails,I imagine that in the 2010 version you do differently.
Does anyone know how? :confused:
autocad use 2010
Hello, I am the author of the video lesson, when you say dynamic quota you mean a normal share of autocad or a dimensional quota i.e. those that vary the value also vary the geometry of the block?
bye, I understand a normal quota that moves by ironing the block and indicates the new measure. not a parametric quota.
At first I thought you used an internal quota command to the editor that I used the classic interface couldn't find. But it doesn't seem like that.
(Thirteenth course lesson 2d advanced - window)
I have reviewed the video in question and actually simply insert a classic autocad quota as a result I think that you have not activated the membership property of quotas (dimassoc), you can verify it by making dx mouse button at any point of the screen, without having anything selected, clicking on user preferences > membership quotation and verify that there is the check on
make new membership fees.
However I have activated on all lessons of the video course the comment option and possibly from there you can interact with me. Hi.
nothing to do,the box in question has already appeared.
Maybe the 2010 version must be different.
I don't have 2010 but I think it's possible to do it with that version.
Can you attach the dwg file in question so I'll take a look?
Magic! I made the block again and now it works,I don't know what I was wrong before(the rest of the block still worked).
Thanks the same.
