share a shortcut radius center
deep70
Hello everyone,
my question is simply that stated in title, that is: is it possible to quote a ray of shortcut (cause too large dimensions)?
I attach an image to make the idea better, thank you all in advance for any given answers and good day to all of you.
according to the baldassini, yes.
then on that design I see a little too many quotas, but maybe it is wanted to provide the maker more reading keys.. .
You are right that there are too much odds, but the customer wants them like this... I meant anyway if solidworks allows to make a share like that.. thank many anyway for the answer-
quoti by selecting the radius center of the angle and the reference element; to remove the center of the quota text otherwise you will go mad to fix it wherever you want
in the figure in black the quotas from the real center and in brick red those from the center of the quota
Thank you so much, as usual number one!
Wait for Mass.. But how do you get the odds in red? to me only the odds in black or the standards..
the red quotas are the guided ones and are my color setting.
I don't even remember because I had changed color from natural gray; I've gotten so used to it that I don't mind
I don't mean the color,, I just can't make the odds that I'm on the sheet. .
I solved it even though I had to struggle a little... it's not something that often happens. learned this anyway. Thanks again.
