etc
I'm just testing inventor, curious about the new release.
work on the realization of small pneumatic presses combined, for drilling/drawing of profiles for lockers.
for each press, we often create the pistons/i from us, so we say that you have a small "free" of pistons.
the "problem" is that, for each press, I cover the parts or the axieme that form the piston in the project folder, and I go to work on that if you need changes, as often happens.
I was wondering if inventor could use parts as a proxy.
es: I am creating the axieme of the press, and the piston add it from my library, or single axieme file, outside the project.. and if I make changes on the latter should not change the original file, maybe a copy is created or you save the changes otherwise.
I hope I have not been too messed up in the explanation
has inventor of the tools that can help me? Thank you.
