shares edited in the table
  • Thread starter Thread starter world
world
Good day to all:
I have discovered, by chance, the presence of some edited quotas and therefore not showing the actual value of the 3d model.
quolcuno knows a way to be able to highlight (for example with other color) quotas with hidden and edited value?
I usually underline them only if you need to change them .cmq your colleague really risks making big messs in your interior.you never do such a job because if you get the details from others, the putting into the table goes after it with the edited value and put in work of the stuff that is not okay.look that you really risk doing mess.
It wasn't even autocad in the times that were something about the edit of quotas....
However I don't think there's a method to automatically detect the "published" odds unfortunately.... more than anything else would be to pull the ears to this colleague and let him check one for one to him and if something 100 euros is thrown less in envelope for every odd!!!! :
I agree in full...
Here.... Then nothing.... you touch the "dirty work" (if I understood correctly you wanted to highlight what was edited right? but you cannot do)
Good day to all:
you could try to export in autocad where, using a free utility made by the comau, you will locate forced odds.
I do not use more autocads from a piece, it can be that in the last rel. there is also a native command that does the same job.
Bye.
I tried with the utility and it works (the utility is called comaulib but I think something like that exists, free, on the net )
you could try to export in autocad ...
in fact on mechanical there is "amcheckdim" that does just this...
