PLOTTER83
I was wondering if anyone could help me. I am drawing a feeding sheet that has a pattern with about 36 folds. I run 2 sketches and then join them with the hopper function, I create a specular copy with the specular command, at this point I must join the two sides of the sheet with a repeat of folds. I create 2 sketches to make 2 faces that immediately join with their fold to the left side of the sheet. I use the rectangular repetition command to repeat 35 times these two faces, but inventor during the repetition does not unite my faces with bending. I parameterized correctly (spero) everything. I tried to make the two faces, with two sketches and then join them with the hopper command, but even these two faces do not join the left side of the sheet. place a file to make me understand (inventor 2011). I hope someone can give me some suggestions. Thank you.
