sheet metal break
  • Thread starter Thread starter Shotfree
Shotfree
good afternoon to all, I have a question to ask you, I have to realize a sheet with two rounded corners, I would like to realize the particular open to the laser, and then bend the straight edges, so far no problem, then I have to realize a rounded corner, welding it along the ray and on the tangent to the stress ray, I can realize the whole edge through the flange function, but I can not realize the tears necessary to development. below I take a couple of pictures to explain better:
1. I realize the face with the final shape of my sheet
1.webp2. I realize the flange, so I have to stop the sheet dive indicated with a tear on the lower flat face and with the adjacent edges on the fold radius (and then fill with a welding:
2.webpThank you for your help!
hi dani, it is not what I wanted to get, in that way the portion of sheet to be soldered is very long and visible, I would like to weld only the radiated part in the corner and a straight part in the bottom (zone not visible).
thanks anyway for the answer
Thank you very much, it is what I wanted, in fact I came to this solution, then to solve the distance between the two plates I then reduced the internal radiation of the sheet, so the stems come closer and weld more easily.
Thanks again.
