sheet metal development in excel
  • Thread starter Thread starter tanticapelli
tanticapelli
for the need for optimization development of sheet metals and other dedicated software I would have the need to export in excel the developments of various types of sheets expressed under the basic form x height of maximum encumbrance.
I know that flat repetition is exportable in dwg and dxf.
can you do something x my need?
thank you are #1!
so many hairs
you can do it using a separate cut (in aminete design) or didactic materials with re-entry (directly in part environment) where you insert the fields boundary length and boundary width that solidworks automatically fills in the creation of the sheet.
in this way carry latabella in excel where you will have a column for length and one for width; If you need to have them in a nica column maybe you can do it through equation, but I'm not sure
I knew it would be enough to ask you!
Big Mass, and I bet you're doing the violinist and the pcs make you throw up!
Thank you again!
so many hairs
