sheetmetal catia v5r19
  • Thread starter Thread starter rai
rai
hi to everyone, I just registered as a result I don't know exactly how to move inside the forum.
my problem today:, I modeled with smd a folded sheet complete with holes. at the time of changing the sketches of various features , holes pockets , fins parameters etc... it fails me all the structure after the modified feature. I find it strange that the sketches are all bound and parameterized. . also a simple rectangular pocket, valuing the shares in the sketch, does not recognize it anymore ...boh..thanks
the information you give is too few.
Maybe you didn't activate the automatic update!
or the possibility of failure of the construction can result from incorrect parameterization.
You tell me about holes (including feature hole), probabillemte tied a hole to the perimeter of the pocket, so the hole falls apart from the particular, so that the system no longer knows what to drill.
if instead it is a sketch with a set of profiles you probably left some incongruence in the geometric constraints.
to identify the problem analyzes the error finastra that appears and invidual on the tree the entity that by error (tsdx on the last line of error, in the pop-up menu choose "graph center").
the error is identified from the exclamation point with yellow background.
